Hi All,
We are running into an issue where our instance gets blocked and caught by recaptcha request. I wanted to know if Yacy supports using proxies for crawlers, and if I can parse blocked request that end in recapcha to trigger a change of the proxy IP?
The way I think this would work is if a page fails with a certain Fail-Response I could set up a script to update the proxy ip through cli/api to use a different IP address when crawling.
