Read title.
This would simply be using the Intranet scan on the cjdns address range, but that is on IPv6 on a not-so-default network adapter. Hence the question.
Read title.
Welcome @parnikkapore!
Well we can do network scanning and that also in an intranet. But the current network scanner uses a IPv4 address schema. So the current scanner is not an option for you.
However there should not be a problem crawling the cjdns network, as long as you find a start address.
The most embarrassing thing is, that YaCy is probably not good at IPv6 Address handling. You should give it a try anyway.
Happy to report that crawling from a start address works so far! Wunderbar!
I hope there will be another DHT up on that overlaynet soon
