There should not be IPs in the logs. If you find some, please quote the exact entry here BUT wipe the actual IP (replace with xx.xx.xx.xx).
I you see IPs in /AccessTracker_p.html
then that is NOT a hint that you have these numbers in the log.
However: P2P does not work without knowing IP addresses of other peers. Every peer has connection information about other peers and stores them - without that you don’t have a network. The /AccessTracker_p.html
pages simply makes transparent that your peer knows these IP addresses. There should NOT be a history of previously connected IPs, only actual IPs of peers.
