Crawl Error: pause reason: network switch to defaults/yacy.network.webportal.unit
Hallo,
I am trying to start some crawls on my dedicated Debian server. But it just gives me the following error message in the “crawler monitor”:
crawl
Crawling with the same settings under windows10 works perfectly but for some reason i am not able to get any crawl running under Debian/Linux at all.
So i need some help here, any idea on how to solve this issue ?
in some cases the switch is not successful without a re-start. Did you try that?
same issue here. Did you find a solution?
