Add admin password?
I installed yacy abotu 2 months ago, then when rebooting the server, yacy stoppe working altogether. It would not run any more.
That’s fine, right? So, I created a new server for yacy to run on. I installed it. It runs fine.
It worked form the same server, I opened port 8090, and it truns.
I tried running from my PC to use it.
It needs a password.
I do nto have one. I use the passwd.sh script to TRY and make one.
It ask for new PW, I enter it.
It asks for host admin PW, I have no idea what this is? I entered the server log in password(Linux MINT has no admin user) for yacy server.
It failed.
I go back to the yacy server, and for anything I want to do, it now needs a password.
How do I set a password? There needs to be a way to do this for the local host interface. The passwd script does not work.
What is the default password?
start yacy up then go to
http://localhost:8090/Status.html?noforward=
look on right hand side of page find this Protection
password-protected [Configure]
click config
Try you, In the file yacy.conf, write: adminAccountForLocalhost=true instead adminAccountForLocalhost=false, and go in the localhost.
see also: Forgot your password
